Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
iPhone Vibrator Need Replacing or Motherboard Problem?
I recently bought a new "complete back housing" for my iPhone 3g and after installing it, the vibrator won't work. I have replaced the vibrator from the complete back housing one to my old OEM one but for some reason both don't work. Is this a problem with the vibrators I have or the connection with the motherboard?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It is very easy to check if the Vibrate Motor functions. Get a regular battery and tape wires to each end, touch one wire to each of the metal contacts on the vibrate motor. The vibrate spindle will spin if Vibrate Motor is good. I bet your Vibrate Motors are good, and the Housing is not fitting right with the Logic Board or something is not right with the Headphone Jack Flex Cable, the one with the Vibrate Switch on it.
Punteggio 0
Yes you we right about the vibrators working but the vibrator on and off switch show a ringer on and ringer off message when I flip the switch...
Punteggio 0
Aggiungi la tua risposta
Jerry Zhu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 925
