Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
Sound For A Minute Then It Fades Out
When I first turn on my iPod I get a severe buzzing sound out of the headphones and the music is very difficult to make out. Then within a minute or two when the unit warms up, both the buzzing and the music slowly fades away until the unit makes no sound at all. The same thing happens when I connect the unit to a docking station.
Any ideas ? Thanks in advance.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Have you dropped it or damaged it recently?
da
rab - I purchased the unit "as is" with the intent of fixing it up - was advertised as just needing a new headphone jack - but I suspect that was incorrect.
Any ideas ?
Thnx.
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Need to do some diagnostics. Put it in the refrigerator for an hour then plug it back in and tell me the results.
Punteggio 4
8 Commenti:
Mayer - You are really good. I left the iPod in the fridge overnight and when I played it this morning it worked fine (no static) for about 1 minute, and then the static kicked in (I guess as the unit warmed up).
What next ?
da
This is indicative of a bad solder connection on the board. As the unit heats up, the connection breaks, and when the unit gets cold, the connection is better. This is a repair for an experience technician. Apple is aware of this problem and, if lucky, you can talk to the right people at their 1-800 customer service number to get it replaced under a "warranty exception". The old number I remember is 1-800-SOS APPLE. If this fixes your problem please hit the accept button located to the upper right of your original question. I've included a picture of it being fixed.
da
That is extremely useful info! i can't figure out why no one else has upvoted it.
da
I've made a couple of (un-friends) on this site for chastising them on really bad answer. I've seen a lot of my upvotes get voted back down.
da
@Mayer I undeleted this post because it contains good info. Our records show you were the one who deleted the post... Not sure what went wrong. If you experience anymore errors like this please let us know. You can contact me directly with chris(AT)ifixit.com or by submitting a guide survey (I read them all). We are always on the lookout for bugs.
da
Mostra altri 3 commenti
Somehow my original post on this question and his response were deleted. I had him put it in the refrigerator for a couple of hours. When he tried it later the problem was gone but then returned in about a minute. I explained about the motherboard solder connections.
Ben- thanks for the up-vote on that
Punteggio 3
1 Commento:
Mayer - thanks for the followup, but I did not see your post regarding the solder connecttions - could you repost it ?
Thnx.
da
Hi,
when the sound fades on the headphone jack and the dock connector, i would suggest that the logic board is damaged.
You can open the iPod an disconnect the headphone jack, if the sound fades as well, its quite clear that the logic board is damaged.
Punteggio 0
Try connecting it to a dock that can play music from (iHome, Apple Universal Dock, Ect.) And see if the music is still messed up. If it isn't, then the headphone jack/hold switch assembly is probably bad.
Punteggio 0
Aggiungi la tua risposta
Boyzgonewild sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,107
