Ssd or the sata cable urgent help needed
Installed a used Kington SSD in a 24” iMac with 3.06 GHz Core Duo and maxed out RAM.
Installation went fine, however after restarting the system the screen goes white, on booting from recovery partition from USB drive it appears that the SSD becomes unintalizd. After formatting it again and installing El Capitan still again it boots on the software but gives the same problem on restart.
Tried several times but the SSD becomes uninitialized every time upon every restart.
Is the blank screen due the SSD or the SATA cable?
Pls help!!!
Update (07/18/2020)
Its an 120gb old version from amazon.also read a similar thread in which said the current sata cable are only enough for the slower hdd drives not for ssd so they said to use pc sata cable.suprisingly 3 people blazened this method correct.pls help i am really confused
Questa è una buona domanda?
1 Commento
Your systems specs: 24" iMac 3.06 GHz Core 2 Duo (Early 2009)
da Dan
