Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
873 Domande Visualizza tutte
I changed my front facing camera and speaker but can only take calls
I changed my front facing camera after damaging the cable whilst changing the battery. I can only take phone calls now on loudspeaker. I’ve changed the speaker but still the same
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Check the ffc connector for damage and reseat. Where did you get your parts from?
Punteggio 0
1 Commento:
OPTIONS
Off eBay. It seems that it’s seated ok would that cause the problem with the speaker not working but only the loudspeaker
da
Punteggio 0
Oh Man! You messed up with your front earpiece flex cable. The flex cable should connect to the board which is responsible to get power to earpiece.
Punteggio 0
1 Commento:
Sorted, it wasn’t quite lined up
da
Aggiungi la tua risposta
gerard morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 51
