Phone will not power on after replacing screen
I just replaced a crushed screen. It was so bad I could not power off and of course now it will not power on….. any ideas?
Questa è una buona domanda?
With a '''USB mini voltmeter''' you can measure the power being sent to your device.
You’re looking for a consistent amperage (red number) between 0.9-1.0A being sent to the device during boot, and while it is running. If this number dips frequently or stays low, you are not just dealing with a display issue. It could very well be a charging port and/or battery issue.
Another thing you can test is the voltage on your battery using a multimeter. If it reads below 3.82V it means that it is not charged, or has failed in some way. By ruling out a potentially bad chargeport first, we can conclude after this measurement whether it is a battery issue or something else.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 38
One thing I had tried when I had this issue when repairing an old 6S for a friend. Disconnect the battery and the screen cables, hold the power button down for 10-20 seconds to remove and residual power in the board. Then re-connect everything and ensure they all click/snap in properly.
da Daniel Fitton
