Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
water damage indicator checking
hello for all wish you all nice day please can you tell how I can know if my iphone 8 plus has water damage i see some topics saying from the sim try slot and other said from motherboard can you please tell me how i can know using both methods ???
note : I attached an 8 plus motherboard tell me please where is the indicator
Questa è una buona domanda?
Punteggio 0
4 Commenti
Can you take a close up picture of the top left side of the board were the antennas connect please
da
And a picture of the other side of the board
da
@barriphone finally some one reply I was waiting since 10 hours this picture is just for information I want to know how I can determine if it has water damage or not please explain the method for me sir
da
You need to take the board out and physical inspect it for corrosion. Check and see if it's been wet. Was water inside the phone. Pull off the black coveralls and check under them. The water Mark's don't really mean anything. If you have high humidity it can cause them to turn red. The only way to tell in to physical inspect it.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
the only way to really determine water damage is to open the phone and look at the LCI.
if you take a look at your picture of the motherboard you posted, see the square at the upper left. look at the thin part of the board where this connects. there is a white oval just above a flex connector. that's the LCI. if it contacts liquid, it will turn red.
Punteggio 1
Aggiungi la tua risposta
tamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 143
