Salta al contenuto principale
The second generation (chassis model L30) was an American market-only version, again styled by Nissan's California design center under Doug Wilson through 1994 (design freeze in 1995).
Will turn over no start
I have a 1999 Nissan Altima Gxe 2.4L engine. The crank will turn over but want start. Have already changed the spark plugs, spark plug wires, distributor cap and rotor. I also just changed the valve cover gasket cause it was leaking and changed oil and filter. It wouldn't start before i did the tune up and valve cover gasket change.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Yes. Changed spark plugs, spark plug wires, distributor cap and rotor. It wouldn't start before I did the tuneup on it. Would turn over but not start
da
Aggiungi un commento
2 Risposte
Did you check for spark and fuel? Did you check the timing belt and make sure it was on time? First steps before you do anything else.
Update (06/24/2020)
You need to see if it has spark and fuel pressure. You need to check and see if the timing belt is broken. There are multiple reasons a car will not start.
Punteggio 0
2 Commenti:
How do you check the fuel pressure
da
My advice is take it to a shop
da
Are you sure the car doesn't have an inertia cut-out, which has tripped (they are designed to turn the engine off in case of accident)? I am not familiar with this car specifically, but the switches are sometimes found in the vicinity of the spare wheel well.
Punteggio 0
Aggiungi la tua risposta
Sean Harkins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 436
