Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 Edge è la versione con schermo curvo dell'S6, il modello al top di gamma di allora.
237 Domande Visualizza tutte
Device not charging or powering on.
I have an S6 edge that is not charging. When you plug it in it says charging with something like 0.3A. I transfered the main board to a working samsung s6 edge but still the same.
Then I replaced the power IC and charging IC and also the same.
When I charge it, the battery logo on my display stays empty. It doesn’t even say %. When I start up the phone it shows the samsung logo and powers off. I read the older samsung phones are known for emmc failure. Anyone have any tips or fixed this problem before?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Seems you have done enough efforts to get you phone alive. But, have you tried a battery replacement. May your phones battery is old enough to hold the charge. Here I must include, no matter how recent you have purchased the battery/phone, modern Li-ion battery loses the charging cycle rapidly if you charge and recharge it rapidly. As per the “emmc failure” , it has nothing to do with charging. However, it can cause you Galaxy get hotter while using or charging it.
Punteggio 0
1 Commento:
Tried 2 batteries. One from a working s6 edge. I put the mainboard in the case and a newly bought battery.
da
Aggiungi la tua risposta
KWH sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 843
