Did you use this Driver Board?
https://www.ebay.com/p/12015167280
I have an empty chassis of the iMAC EMC 2429 except for Left/right speakers.
I installed the Driver Board kit and hooked everything up and it now works as a monitor via HDMI.
I notice the Driver Board has Speaker Output and what looks like a 3.5mm connector for AUDIO.
HOW DID YOU CONNECT THE INTERNAL IMAC SPEAKERS TO THIS DRIVER BOARD??
btw, How did you Power the Driver Board,
I used a 12V/5A supply and notice this Power Supply gets pretty HOT.
I also noticed the LCD display itself also gets WARM…I assume this is normal.
I notice the Left Speaker has a 5 pin connector
I notice the Right Speaker has a 4 pin connector
Speaker Connector PINOUTs for Logic Board 820-2828
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
