Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
iPhone 8 Plus Won't Turn on After Replacing Screen and Battery
Hey guys, recently I just replaced my iPhone screen and battery simultaneously. I put all together and it works great. However, I woke up the next morning to the phone completely dead. I thought it’d be a simple fix but my phone won’t reset, turn on, or anything. I’ve tried everything to figure out what the problem could be I disconnected the battery and put in the charger but the screen won’t turn on either so I took out the screen and installed my old broken screen with the charger and still nothing worked. I examined the connectors and everything on the phone but everything looked fine. I could really use some help here because I’m just in high school and can’t afford a new phone.
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Did you try putting in the original battery? Did you try hooking it up to a computer and seeing if iTunes will recognize the phone?
da
Did you try a different charger? Have you used an aftermarket charging cable before?
da
I did try putting in the original battery and screen and arose with the same issue. I hooked it up to the computer and it refused to even recognize the phone. I tried an aftermarket cable then tried an original cable
da
Aggiungi un commento
3 Risposte
Put back your old battery or buy a new battery and see if the phone boot up.
Punteggio 0
1 Commento:
I did put in the old battery however the LCD screen did not show any thing. I also put my old screen and nothing came up
da
If Phone worked fine, then most likely battery and LCD is fine. Battery most likely had a charge in it and couldn’t charge back up due to pry damage to the Moffset(s) in the picture. If you are handy with a multimeter or have magnification… look around the circled area for missing/lifted or damaged components needed to charge your battery. Or use a Multimeter in “Diode Mode” to take the readings of the battery connector and see if they are correct or show “OL” (Open Line).
Punteggio 0
1 Commento:
I do not have those tools handy, I'm only in high school. I'm attempting to see if my AT&T has insurance on my phone to replace everything for me
da
It sounds like a possibility that the tristar ic was damaged and it will stop charging and data transfer on the phone.
Update (06/19/2020)
Take it to a repair shop and have them test the tristar ic. It only takes a few seconds and most places will do it for free.
Punteggio 0
1 Commento:
Another thing is I did plug it in before and it charged fine. I woke up and the battery was dead, I have no idea what to do
da
Aggiungi la tua risposta
Tyler p sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,366
