Salta al contenuto principale
A machine of the family of BSH household devices built by the Swiss OEM company Eugster. There are many similarities in its construction with machines by Bosch, Melitta, or Nivona.
3 Domande Visualizza tutte
outlet valve on my TK52001 / 02.
I have replaced the outlet valve on my TK52001 / 02. Unfortunately, I got it turned in the wrong direction. I've turned it right now, but no coffee will come out. What could be the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you solve this issue? If you just repeat the whole process it should be OK.
Punteggio 0
1 Commento:
No it do not work. I will try to change the drainage valve
da
Aggiungi la tua risposta
bobbe39 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 290
