Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
iMac iSight camera to USB Pinout
Hi all,
I deconstructed my iMac and made it into a functioning external monitor after it broke.
I want to re use the iSense camera by making it a USB device. I have heard of people soldering the cables onto a USB for use. The issue is, there is 7 wires and I am not sure which wires to attach to the USB as they only have 4 connections. I have attached an image.
Thanks in advance
Questa è una buona domanda?
Punteggio 3
1 Commento
Is the camera 3,3V or 5V ?
da
Aggiungi un commento
7 Risposte
Soluzione Prescelta
I also have a 2011 27" iMac, but clearly different color wires.
I reverse engineered Virtual Drivers video to get the pin order, not the colors since those change even between the same models.
For my 2011 27" iMac 7 wiring is as follows (camera facing you, looking at the QR code, from left to right):
wire 1 black - x
wire 2 purple - x
wire 3 brown - x
wire 4 black - black
wire 5 grey - green
wire 6 green - white
wire 7 blue - red
Punteggio 4
5 Commenti:
thank you finally a pinout that works!
da
Thanks for this. This worked for me. All of the suggestions which rely on colours aren't helpful. I have 3 - 2011 iMacs and each one has different coloured wires! I think the key is (as you said) wire location relative to the camera on the plug. The last 4 wires (away from the camera when plugged in) are the only ones needed. Also, after stripping the cable, I only had 6 wires. The thick Black #1 wire wasn't in there. Just to demonstrate, here are my wires used.
Plug > USB
#4 (Brown) > Gnd (Black)
#5 (Grey) > Data +ve (Green)
#6 (Purple) > Data -ve (White)
#7 (Blue). > Power (Red)
da
Will this work with a iMac 21.5" 2014?
da
@poesis3d Its works for me too :-) Thank you very much. My iMac 2011 27 has this color on the cable.
da
@poesis3d it also works for me. In my case, it is an iMac mid 2011 21.5”.
da
To connect iMac iSight camera to a USB connector
Camera wires to USB cable wires
  • Black - Black
  • Blue - Red
  • Brown - White
  • Purple to Green
The first two are power, the last two is the data output.
Update (06/19/2020)
Are you sure the camera is working?
Here’s the other side connection verify the lines
PP5V_S3_Camera is the positive power line (Red) and the frame ground (Black) is the negative side. Do you measure power?
Punteggio 3
8 Commenti:
Thanks for your reply! So apart from these 4, I do not need to connect the other wires?
da
They are the microphone lines (analog) unless you have a DAC to convert the signal you can't use it.
da
Awesome, you're the best man. Very greatful
da
Hi mate, I tried connecting it in the way you said but got nothing!
da
Hi Sumeet, Did you ever get the camera to work? My 2011 iMac's wire colors exactly match yours, which are different than Dan's, John D's and Virtual Driver's (video). I've tried all these combos and nothing works.
da
Mostra altri 3 commenti
You can find the correct pin out of the board and just match it to the standard USB Type A pins
https://s5.electrodragon.com/wp-content/...
There are two GND cables coming out of the cable. I used the smaller cable and left the big one alone (not connected)
Works like a charm. It took me a long time to find out the correct pins.
Hope that helps.
Punteggio 1
1 Commento:
https://s5.electrodragon.com/wp-content/[url=https://drift-hunters2.co]Drift Hunters[/url] I find it quite difficult
da
Can share which wires connect?
Punteggio 1
2 Commenti:
Imac 2011 27inch isight camera to usb
usb to camera wire
black— blue
Red-grey
green - purple
white-red
da
This worked for me!!! Thank you!!
da
Hi,
Is the camera 3,3V or 5V?
Thanks
Punteggio 0
1 Commento:
Don’t know. It just works on usb power.
da
Has anyone achieved it with this camera model or know how to do it? (2017/2028 model) Thank you
Punteggio 0
I‘m also interested in a solution for the 27” iMac (2014-2017).
Any help is appreciated.
Punteggio 0
Aggiungi la tua risposta
Sumeet Saini sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 177
Tutti i Tempi: 7,429
