Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
So my MacBook Pro won't turn on anymore
So my 2009 MacBook Pro will not turn on anymore. I’ve tried resetting the SMC but still nothing. It will just show the white light at the bottom of the MacBook. It had macOS El Capitan. I do not want to have to buy a new laptop since I am broke.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
First lets seee if we can get it to spontaneously reboot. Disconnect the mag-safe adapter and then the battery from the logic board. Press and hold the power on button for ten seconds. Now reconnect the battery and then then mag-safe. It should reboot.
See step #3 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement
Punteggio 1
2 Commenti:
I've tried that it
da
If it won't spontaneously reboot, it's usually a logic board issue. Visually examine the board for corrosion or burned components.
da
Aggiungi la tua risposta
Asim Zahir Ali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 49
