Salta al contenuto principale
MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement
Cosa ti serve
  1. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Remove the lower case screws: passo 1, immagine 1 di 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Lift the lower case away: passo 2, immagine 1 di 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Battery: passo 3, immagine 1 di 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Display: passo 4, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Display: passo 4, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Display: passo 4, immagine 3 di 3
    • Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
    • Be very careful to pry under the connector as shown, and not under the socket itself. Otherwise you may accidentally separate the socket from the logic board.
  5. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 5, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 5, immagine 2 di 2
    • Disconnect the camera cable by sliding it horizontally out of its socket.
    • Pull the cable parallel to the surface of the logic board, in the direction of the optical drive. Do not pull straight up, or you will destroy the connector.
    • If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
    • If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
  6. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 6, immagine 1 di 1
    • De-route the camera data cable from the channel in the optical drive.
  7. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 7, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 7, immagine 2 di 2
    • Remove the following screws securing the camera data cable and right speaker to the upper case:
    • Two 8 mm Phillips screws.
    • One 4mm Phillips screw.
    • One of the 8 mm Phillips screws will likely remain captive in the camera cable ground loop.
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
  8. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 8, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 8, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 8, immagine 3 di 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
  9. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 9, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 9, immagine 2 di 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips screw.
    • One 5 mm Phillips screw.
    • Lift the display data cable bracket out of the upper case.
  10. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 10, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 10, immagine 2 di 2
    • Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
    • Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
  11. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 11, immagine 1 di 1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, use your Torx driver to remove the remaining 6.5 mm screw from the lower display bracket.
  12. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 12, immagine 1 di 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  13. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 13, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 13, immagine 2 di 2
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
  14. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 14, immagine 1 di 1
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
  15. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Clutch Cover: passo 15, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, Clutch Cover: passo 15, immagine 2 di 2
    • Grab the clutch cover as shown and slide it toward the right side of the display.
    • It should move about 1/4" and stop. Don't force it beyond this point.
  16. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 16, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 16, immagine 2 di 2
    • Gently rock the clutch cover back and forth on its long axis while pulling it away from the display.
    • Do this action along the length of the clutch cover until you can lift it off the framework attaching it to the display.
  17. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 17, immagine 1 di 1
    • Remove the clutch cover from the display.
  18. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, AirPort Connectors: passo 18, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, AirPort Connectors: passo 18, immagine 2 di 2
    • Use the tip of a spudger to pry both AirPort antenna connectors out of their sockets on the AirPort board.
    • Be careful not to break the sockets off the AirPort board.
  19. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement, AirPort Card: passo 19, immagine 1 di 1
    • Remove the single 3 mm Phillips screw securing the AirPort card to the display nearest the AirPort antenna.
  20. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 20, immagine 1 di 1
    • Remove the single 3.3 mm Phillips screw securing the camera cable retainer to the display.
  21. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 21, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 21, immagine 2 di 2
    • Orient your display as shown and pull the black plastic camera cable retainer toward the right side of the display.
    • Remove the camera cable retainer.
  22. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 22, immagine 1 di 1
    • Carefully pull the camera cable connector toward the right side of the display and out of its socket on the AirPort card.
    • When reattaching the AirPort Cable, make sure that the U-shaped notches on one side of the cable end are not visible (facing the card). If the cable is installed incorrectly, it will cause logic board damage.
  23. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 23, immagine 1 di 1
    • Remove the remaining 3 mm Phillips screw securing the side of the AirPort card closest to the right clutch hinge.
  24. MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 24, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement: passo 24, immagine 2 di 2
    • Pull the AirPort card away from its heat sink and remove it from the display.
    • Before installing a new AirPort card, be sure the thermal material on its surface is intact and aligned with the small heat sink on the display frame.
Conclusione
Altre 64 persone hanno completato questa guida.
5 Commenti
I am sick of the occaisonal misinformation iFixit provides. The longer cable that connects on the right side of the screen is so very obviously not just the camera cable. It is also the cable for the Airport and Bluetooth cards... This misinformation led me to spend 100€ on two LCD cables which I now have no use for.
I don't wish to just complain though of course. Can someone please correct this? On the other pages for this MBP the cable is listed in the same way.
spacec0w - Replica
The official Apple name for this cable is "camera cable", so that is what we call it. You'll have to take it up with Apple to change the name, as we try to stay consistent with how they name parts.
Andrew Bookholt -
I think iFixit does an amazing job of being accurate, given that the guides are written based on physical tear-downs. As a small-time mac technician, I am eternally grateful for the unlimited use of free, comprehensive guides. Instead of complaining about free advice, you can easily submit an edit to the guide if it is truly in error. The bottom line with Apple products - they are impeccably engineered, although have some annoyingly tedious steps because of the compact nature. They are build to last, but BE GENTLE!!
Logan Bean -
The connector from the cable into the airport card is socketed in different ways on the pictures in step 21, i have noticed that the connector fits in either way, but what way is the right one? im asking because after i followed this guide my airportcard doesnt work anymore:(
info - Replica
see comment on step 22
Logan Bean -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 162
Tutti i Tempi: 109,910
