Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
20 Domande Visualizza tutte
My Phone Is Water Damage
I have water damage s10 plus it's not turning on what is the problem with my phone battery issue lcd issue or anything else?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
If it's water damaged it could be anything. Once it gets wet and has voltage running through it, it will start to corrode on the connections immediately. You will have to take the phone apart and clean it up and find any shorts and probably a new screen and you will most likely still have issues with the phone. Most repair shops won't work on phones that are water damaged except to extract data because of all of the problems and all of the future problems.
Punteggio 0
Aggiungi la tua risposta
rashdiziad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,990
