Witch differential oil to use
Anyone know the exact differential oil for 2000 Dodge dakota 2wd? Not sure to use 75w90 or 80w90.
Questa è una buona domanda?
It should tell you in the owners manual but there isn't a big difference you can use 75/90 80/90 it doesn't really matter. You can use standard or synthetic. The only thing you do need is the additive if you have a limited slip differential. If only 1 tire spins in the snow then you don't have a limited slip differential.
Ultime 24 Ore: 5
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 76
Tutti i Tempi: 1,715
