Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
Questa è una buona domanda?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,259
1 Commento
Of course the engine turns over, and there's a spark from the coil wire?
da originalmachead
