Salta al contenuto principale
The Nokia 6030 is a GSM dual band handset with automatic switching between frequencies.
How to repair power button?
The Nokia 6030 has its power button on its top as part of the back casing.
I have noticed that the button does seem to work/respond very well anymore on a unit. My impression is that its alignment with the contact it presses into may not be correct. Perhaps the button is somewhat warped.
It looks like the button may be removable, but I have not been able to remove the button with decent pressure from under where it appears to be attached.
How can one repair the power button? Can the repair be done without replacement of the back casing itself?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Nokia 6030c-2 many bottom not working problem
Punteggio 0
1 Commento:
Nokia mobile 6030c-2 many boton not working problem
da
Aggiungi la tua risposta
User5 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 173
