Salta al contenuto principale
Un eReader touchscreen di Amazon con pulsanti silenziosi per voltare pagina e retroilluminazione a regolazione automatica, rilasciato il 21 ottobre 2014.
Water Damage- Touch Screen Unresponsive
Hello :) I left my Kindle Voyage in the rain (devastating)! After a few days in rice I plugged it in and turned it on. To my surprise- it turned on and lit up. However, the touch screen isn’t working. The side buttons still vibrate and work, I just can’t select a book or anything because the touch won’t work. Is this something that is fixable? Or is it gone forever? Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello,
if its water damage, you have to check with the professional technician, it might be due to water still exists or damage the components inside as well. they will able to clean and check with isopropyl alcohol or ultrasonic cleaner.
if you are able to open, please attach the picture.
Punteggio 0
Aggiungi la tua risposta
Ashley Edwards sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 28
Tutti i Tempi: 609
