Salta al contenuto principale
La revisione del 2016 di Apple alla propria gamma di laptop indirizzata agli utenti professionali. Adotta un display Retina da 15" e 2880 x 1800 pixel, processore quad core Intel i7, opzioni SSD da 256 GB, 512 GB, 1 TB, 2 TB, 16 GB di RAM e tastiera dotata di Touch Bar. Rilasciato a novembre 2016. Modello A1707.
260 Domande Visualizza tutte
What causes these moving horizontal lines on display?
I’m assuming the issue is caused by a damaged display and that I would need to replace the display assembly to resolve the issue, but I thought I would ask about it on here to see if it might be related to something more specific. Note that the horizontal lines in the pictures are separated into 6 columns of equal width, covering the width of the display, and they are constantly jiggling around. They are mostly pink and light blue / green. The right-most column of lines is less dense. Any advice is appreciated, thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, your display is damaged, more precisely the T-CON board has failed. This is the thin board held in the uppercase.
Most laptop displays have it within the lid. Apple decided to be different! They placed it into the uppercase in the worse location! It tends to cook!
Sadly, once damaged it is not repairable and Apple only sells the full assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide Sostituzione Schermo MacBook Pro 15" Touch Bar fine 2016
Immagine MacBook Pro 15" Retina (Late 2016-2017) Display Assembly
Prodotto
$507.99
Punteggio 2
Aggiungi la tua risposta
Zach sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 518
