Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
387 Domande Visualizza tutte
Dualshock 4 works on PC (via cable only) and does not work on PS4
I'm having problems with my Dualshock 4 controller.
When connected to the pc via cable it works perfectly.
When I try to play with it on PS4, with cable, it works for a few seconds and simply turns off the controller.
Sometimes, before he hangs up, he goes crazy, pressing L2 forever and turning the analog ones to the sides. But it is rare.
I tested it on DS4Windowns and it always shows as 0% Battery, even if you put batteries from other controls that are working.
When I press the PS Button with the controller off the cable, nothing happens.
What can I do ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I have heard that fake ps4 controller will turn off after a certain time when it's connected to a PS4 (but usually, it will do this after few minutes not seconds). Could this be a possibility ?
As for your controller going crazy, it probably register the last analog fonction you press while it turned off. As the controller is no longer connected it can not communicate with the console that the analog fonction is no longer in use.
Punteggio 0
2 Commenti:
I really don't know, whether it is or not.
I don't know how close a copy is to the original.
But I am 99% sure that it is original.
and now the light has changed, in pairing mode the light flashes yellow.
I'll leave the photos of the motherboard and the bluetooth card
da
Eum, it definitely looks like an original one. I can't tell what's wrong.
da
Aggiungi la tua risposta
LuccaBR1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 234
