Salta al contenuto principale
The Wonderboom is a Bluetooth portable speaker from Ultimate Ears. Released in 2017. Model number: 984-000839.
Is it possible to replace the battery?
The speaker fell out of my bag as I was going into mye car, and I accidentally drove over it. Some og the casing were broken but it would still connect to my phone and I could even play songs on it. But I was worried the battery could have been damaged, and after I took everything apart, the battery is clearly damaged. The weird thing is that all the other components were fine. Is it possible to get a replacement battery?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here’s one possibly 3 line 3.8v lithium ion rechargeable battery You will need to check the lines as your battery appears to have two lines for the positive and negative pads.
Punteggio 1
Aggiungi la tua risposta
Per Henrik Mork Viken sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,432
