Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake"e 4 porte Thunderbolt.
239 Domande Visualizza tutte
Lines across the bottom of screen
Theres a problem which started yestersay where there were lines at the bottom of on Macbook's screen. It forms like bottom of the screen of when it start. (If you don't understand you can look at the image) It also fades a little when I don't use it. (Like in the image) The mouse is still slightly visible when its moved toward the glitched area. The lines also flicker very slightly.
I think the cause of this was the Macbook overheated and brunt some display cable in the device. I have been using it for very, very long. It was also making air rushing noises.
If you could see whats going on and suggest a way to fix it I would be very grateful. Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
You’er not alone!
Gradiant dark shade in bottom of screen, doing video editing
Punteggio 1
For me it gone by it self maybe u can clean the fans and the macbook and let to cool for a while
Punteggio 0
Aggiungi la tua risposta
Damien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 55
