Salta al contenuto principale
La famiglia MacBook è stata introdotta nel maggio 2006, sostituendo l'iBook nel ruolo del laptop Apple indirizzato al mercato consumer.
3786 Domande Visualizza tutte
Battery is Not recognized - Shows (X) out in Menu Bar
I have a White 13" Macbook. The battery is no longer working. It shows as X'ed out in the menu bar. When i plug in the Power cord it goes Green immediately. It does not charge the battery at all. The laptop runs fine off the Powercord but dies if i unplug it. I tested the power cord and battery on a similar macbook. So it seems that it would be the computer. I did try and replace the keyboard before this all when down but the battery was fine or a week or 2 before it went X'd out. Does this sound like it could be fixed by replacing the "Batter Connector" or a Logic Board issue? Reading the posts it sound like if the computer works then it would not be a logic board issue?
Any thoughts?
Thanks
Aaron
Questa è una buona domanda?
Punteggio 5
3 Commenti
Is the X red or black?
da
The X is black
da
Wouldn't it show up as an X on a different laptop if the battery was bad? I put it on a similar laptop and it starts charging just like normal and shows up in the task bar without the X.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's our previous answer on this: Black x in the battery charge symbol?
Punteggio 3
Check in sys profiler about cycle count.
Must be battery gone.
Punteggio 0
Aggiungi la tua risposta
Aaron Brock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 13,163
