Salta al contenuto principale
Brother All-In-One Monochrome Printer.
Printer stops partway through printing. Indicates a paper jam.
Hi all,
Perhaps someone here has had the same problem with this model or family of printers and has found a solution.
I’ve cleaned all the rollers that I can find:
1) Pickup rollers in the paper drawer,
2) Under the drum/cartridge,
3) At the back of the printer through the tilting cover,
4) At the final output.
I followed Brother’s advice and used alcohol first but then bought a rubber renew product by MG Chemicals called “Rubber Renue”. The latter took made the rollers fresh-looking again. Be careful that you don’t get it on the plastic parts as it seems to melt them a little. :^)
It still didn’t work so I called Brother and they had me go through some steps to see where in the paper path the problem was happening. To do so, they asked me to open the back door, feed paper into the single sheet feeder, and then press the following key combination to get into a maintenance mode:
Please read the following instructions carefully in order to access the  MAINTENANCE menu of your Brother Printer.
1. Please make sure the screen of the printer is on the home screen. If it is not, please press on the Red [X] to return to the home screen.
2. Press on [FAX] - The [Home] Icon will light up.
3. Press and hold the [Home] Icon until the screen changes to a black screen with four rectangles. It will first go back to the Home screen, keep holding it and it will change again.
4. Press and hold the bottom rectangle until a Number Pad appears on the screen.5. On the Number Pad, please enter the following 5 code numbers in order, as quickly as possible: [*] – [2] – [8] – [6] – [4].
6. If the code is entered correctly, the screen should display: MAINTENANCE right above the Number Pad.
7. Now press 77 and press Mono Start.
After about 10 seconds it should print out a diagnostic page. Mine jammed, of course.
In the picture below you can see how far the paper travelled until it jammed in my printer…
Any help with this would be greatly appreciated.
Questa è una buona domanda?
Punteggio 1
1 Commento
My MCF-L2740WD is also doing exactly this. It was fine for 2-3 years and then suddenly started doing this. Every attempt at printing results in this same outcome. The paper ends up in the exactly the same position as that shown in the photo. It does not appear to be jammed and the paper is in near enough perfect condition once it is pulled out. Something appears to be falsely registering a jam, and stopping the printer.
I have tried many things (cleaning, factory reset) but to no avail. Next step seems to be disassembly, but I would rather not.
Just wondering if you ever resolved the issue?
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Hi Chris,
Unfortunately, I was unable to determine a solution to this problem. I spent some time on the phone with a technician who ran me through the steps in my first post above. When the paper jammed again, he said that I'll have to buy a new printer. :^) How convenient! They did give me a good discount on a new one and I just ended up buying the MFC-L2750WD, which has been working really well since then. (Fingers crossed.)
I'm with you, though, in that there is some sort of sensor that is stopping the paper from feeding right through. It could be something as simple as a loose belt which is not allowing one of the rollers to spin at its proper speed which is being picked up by a sensor of some sort, most likely optical.
Good luck to you.
Cheers,
Barry
Punteggio 1
3 Commenti:
Hi Barry.
Thank you for the update. Sorry you didn't have any success in repairing the 40WD, but glad the 50DW is still going well.
For any that come across this thread in the future. I disassembled as much as I could in the likely problem area which amounted mainly to the removal of the fuser unit. Cleaned as much as possible. After reassembly I retested. I was about to give up when a print went through, no jam. This is not resolved though as it is very random, and only roughly one in six prints are successful i.e. it is still not usable. I found the best way to test was just to print a single blank page, using the manual feed tray to eliminate any possible problem with the pickup from the auto tray.
I know printing is also okay, or at least about a half of the page gets printed before the supposed 'jam' occurs. Although the fuser only gets to 'fuse' about a third of the page which is about right, but it does seem to demonstrate that fusing is fine too.
If I have any further success I will give an update.
da
Buy a new printer. At a certain point of time, the cost of which is less than the time (wasted) fixing the jam. Stan Lerner
da
Exact same problem and exact same non-help from Brother support. When I tell them that machine copies but jams when printing nobody has a clue what that means. All they can do is read from a script that has you taking stuff out and looking for scraps of paper. Even after telling them that it copies OK they still want to look for scraps of paper. I deleted the software and reinstalled but still jams on printing. The deal they offered to me for a replacement was higher than the Amazon price.
da
I had *precisely* this same issue with this printer. I replaced the drum unit (not that there was any solid reason to) and that fixed it.
Punteggio 0
I had this same issue tried to replace a lot of different parts like the drum with no resolution. Finally replaced the PAPER EJECT SENSOR PCB BOARD, sensor that the paper lever in the back of the machine senses and the printer printed again. It's a pain to replace as you have to fish the wires with a 2 prong connector through a crazy routing area but was the only thing wrong with it so I found it to be worth it.
Punteggio 0
I had this same problem with the paper stopping halfway through the cycle when printing and copying was OK. I deleted all Brother software and drivers and reinstalled and huzzah everything worked. I noticed that the downloaded software was dated June 2025 which is quite different than the software I previously had installed.
Punteggio 0
Aggiungi la tua risposta
Barry Fence sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,454
