Salta al contenuto principale
The Toshiba Satellite L505 is a 15.6 inch value notebook computer.
6 Domande Visualizza tutte
printer won't work properly
My HP and Canon printers will not print from file, i.e. letters or documents. I updated the Word drivers, no help. It does print test sheets and PDF files. hit the usual suspects removed and replaced printer, cleared spooler etc.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If both your printers are not printing documents or letters, but may still print test sheets or PDFs, it could be unlikely a hardware issue.
If only certain documents aren't printing, check whether the document is corrupted. Try printing different documents, such as new text files or letters, to determine whether the issue is with a specific document.
  • If a specific document won’t print, try opening it on another device or printer to see if it’s a document issue.
  • Convert the document to a PDF and try printing that instead.
To check if the issue is with the printer or your laptop: Try printing from a different computer or mobile device. If the printer works from another device, the problem is likely with your laptop's settings or drivers.
Punteggio 0
Aggiungi la tua risposta
sandy bartley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 54
