Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
Colourful lines across screen when fully opened?
So this just started happening yesterday and I’m not sure if it’s a Flexgate issue. I have a crazy amount of lines across the screen that flicker and disturb the visual clarity. If I plug in a monitor or close the screen to 30 degrees it all goes away. What’s peculiar is the lines get more intense depending on the open windows, or position of windows in the screen. It’s really frustrating because i desperately need my macbook for work and all repair places in Australia are full up for weeks. I bought it in 2018 and it’s a 2017 model. I’ve attached some pictures and you can see how it changes when i change windows or move them
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I do fear you have a display type of issue but its not original FlexGate issue which was the backlight ribbon cable was getting damaged just using the system.
Here I suspect the T-CON board has failed (which is part of the display assembly) lets make sure, plug in an external monitor via TB3 to HDMI or VGA dongle to your TV or monitor. Does the problem show up there? If not then we know its the T-CON. If it’s visible on the external then the issue is within the logic board graphics services (here the Intel Iris Plus Graphics 640 engine within the CPU unit).
Depending on where you live you may still have warranty coverage! The EU has a two year requirement. Even still you might have an out if you bought AppleCare+ support contract.
Otherwise you’ll need a new display assembly to fix this. Are you up to replacing it? Do you have the needed tools and finger dexterity?
Punteggio 1
2 Commenti:
Hey Dan, thanks for the quick response. I’m not sure what Tb3 is - is it thunderbolt 3? When I plug it into my tv via hdmi there’s no problem with the picture. And if I almost shut my macbook screen the problem goes away at about 30 degrees open.
no Apple care unfortunately and australia region is only 1 year warranty. Any idea how much it’ll cost? Cheers
da
@simonmon Thunderbolt 3 (uses the same connector as USB-C) but its not the same signal set!
See if you can get it covered under the FlexGate extended warranty, can't hurt to try!
As far as getting a replacement display: 13" MacBook Pro Complete Display - Space Grey, Apple P/N 661-07970 (Used Grade-A) which is $536.52 USD
da
Aggiungi la tua risposta
Simon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 123
