A MOD, not a repair: Adding MORE than just one harddrive?
I already replaced the internal DVD drive with a harddisk.
But he space is there, why not removing the internal 7hours battery and place some extra USB2.0 Harddrives INSIDE the Macbook Pro and hook them to the USB ports?
(There is only 2 internal sata ports in a Macbook Pro) Now, it sems that the Macbook does not only need the battery for keeping some preferences like date and time , but also uses it´s addiotional power when doing cpu-intensive tasks. Mine can be down to 90% when doing rendering for one night. So I guess a smaller battry must be used while making up space for two harddrives in the battery compartment. Using 4 750gb disks, it could be about 3TB in a Macbook pro.
So here are my questions:
-What are the exact voltages of (I guess there are several) of the battery?
-Does anyone know the pinout of the 10-pins battery connector?
-Does the system measure only the voltage of a battery when loading, or also the amperes?
- The USB-cables of the extra harddisks should be soldered to the USB-connectors on the logic board.
This is only possible with very thin wires or a flexible flat cable. Do USB specifications allow such cables, probaly ushielded? (Distance will be around 15-20mm.
Thank you, all the best, Herbert
Update
Hello to all,
thanks for the answers!
Well, first of all: Working as a film-editor, you NEED storage. The footage of my recent documentary uses almost 3TB.
About powering the drives: The footagl is already on three 1TB, usb powered harddisks. The mac´s usb-bus has no problem in powering them.
Two buses would be "lost", woth the mod there is still one left for adding an USB.hub externally, for printers, burners etc.
But the big problem lithium-ion polymer battery: It´s cells need to be carefully balanced during charge by the mac´s echarging circuitry, so putting in a smaller type to make room for the hd´s seems to be a no-go.
All the best, Herbert
Questa è una buona domanda?
3 Commenti
This is a pretty risky venture you're willing to undertake on a new machine. I honestly recommend you try this type of "Frankenstein" mod on a older machine before you risk blowing your new machine to bits. Just my opinion.
da Majesty
I agree, IMO it would really be a waste of time/money. Why do you need so much internal storage? The WD Scorpio Blue is a 9.5 mm 1TB drive, so you could theoretically have 2 TB of storage with your current setup. Do you really need to carry around an additional 1000 GB on top of that? I would put an SSD as your boot drive, install a 1 TB drive in an optical drive enclosure, and get some external hard drives. If you need mega speed, drop some dough on one of these.
da Andrew Bookholt
Agreed. Having 3TB on a notebook seems like overkill. It seems like the bigger HD's get the more people want or demand. a few years ago having 250GB was considered more than enough.
da Majesty
