Salta al contenuto principale
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
No Display back light only - can't see icons wont display externally
Does anyone know if the GPU is upgradeable or replaceable? on the iFixit teardown, I cannot see where the GPU is on the logic board or whether it’s a replaceable part?
The issue is Currently, the iMac turns on and chimes and but no display, just backlight glow and can’t see any icons using a torch. It also won’t display externally using an external display port.
Any ideas?
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sorry, the last replaceable GPU MXM board model was in the 2011 models.
This model does not offer a dedicated GPU, it only offers the Intel HD Graphics 6000 or Intel Iris Pro Graphics 6200 which is within the CPU chip.
You’ll need a to replace the logic board. Sostituzione scheda logica iMac Intel 21.5" EMC 2889
You’ll also need these tools:
  • Plastic Cards you should get two sets
  • iMac Opening Wheel or if you get the [prodotto collegato mancante o disabilitato: IF173-005] you’ll get the tool with it.
Immagine Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172
Prodotto
Plastic Cards
$2.99
Immagine Cutting wheel for releasing the adhesive on some iMac models.
Prodotto
iMac Opening Wheel
$7.99
Punteggio 1
1 Commento:
Thanks Dan, this is what I was thinking.
da
Aggiungi la tua risposta
Craig sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 75
