Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
Why can't I seat display cable
I bought a second LCD display because I thought I may have done something to the cable end coming into the unit. It doesn’t seem to be it. I’ve no power at all to the LCD though I have an external display, not only is no power reaching it, it isn’t recognized by System Preferences. This is my first MacBook repair. Any and all tips appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you take a few pics so we can see what you are encountering, post them here Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly the socket was damaged somehow. It looks like someone pulled straight up Vs sliding out the tang to the side as outlined in the guide MacBook Pro 15" Unibody Mid 2010 Display Replacement as stated in Step 15.
Sadly its time for a new logic board as being the easiest fix, otherwise you’ll need to find someone with the needed skills and tools to replace the connector, but that still assumes the logic board is good, that’s a large gamble here.
2010 15” MacBook Pro Logic Board 2.66GHz i7, Apple P/N 661-5480
2010 15” MacBook Pro Logic Board 2.8GHz i7, Apple P/N 661-5803
Here’s the guide you’ll need to follow to install it: Sostituzione scheda madre MacBook Pro Unibody 15" metà 2010
Immagine MacBook Pro 15" Unibody Mid 2010 Scheda madre
Guida
Difficoltà:
Difficile
30 minutes
Immagine MacBook Pro 15" Unibody Mid 2010 Display
Guida
Difficoltà:
Moderato
1 - 2 hours
Punteggio 2
1 Commento:
Thanks ! The dummy was me ! Iswore I came out parallel to the board, but either i did pull up or my explorations wounded it.
I'll follow the links to check prices, but I need a part # for the connector just in case. The rest of the system is fine.
da
Aggiungi la tua risposta
James Walker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 46
