power on - lights on - sensors make sound - nothing moves?
I have power and lights but when I touch any button or the control knob, the sensors make sounds but nothing moves. Ive unplugged but nothing. every once in awhile it tends to work for a few seconds and then freezes. the manual says possible control lock, but there is nothing that I can find to reset.
Update (04/05/2020)
This is a Mod #110.31632611 5.3 cu ft type 706-01 top loading machine
Questa è una buona domanda?
Punteggio
2
Please check the model number as I am not getting anything with it.
da mayer
That is the model number off the tag on the machine. I may have been wrong with the 5.3 or 6.2cu ft but the mod and type are correct.
da keith masker
Again, the lights will come on and as I push buttons or turn the dial I can hear the sounds that it usually makes but the lights are frozen and it wont start.
da keith masker
I had similar issues with a Samsung washer. I ended up having to replace each PCB until I found the bad one. If you can locate a wiring diagram, you can narrow down the likely board by looking for for the control signals that drive the motors. This isn't a fool-proof method by any means as I had to replace every board until I found the faulty one. I wish you luck on this one!
da Napoleon Blownapart
