Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
563 Domande Visualizza tutte
Why it take to much time to wake up after sleep?
When I close the computer cover and open it again it takes too long to wake up
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
too long means what? 1 min or 2 min?
BTW do you have too many apps installed. Go to Finder->Applications
Remove unwanted. YES. Move to trash.
A lot of programs these days use background services to Monitor and WASTE computer resources. All this will need to somehow written to RAM or DISK depending on sleep mode.
Or do a fresh install.
Go to Activity Monitor and see what is using much RAM/CPU.
Launch Pad -> Activity Monitor
Insatll this and clean (open source program)
https://www.bleachbit.org/
Punteggio 0
2 Commenti:
1 min and sometimes 5 minutes, I erase the computer to check that and the problem still. This happens to when i shut down in the night and in the morning the macbook take to much time to turn on.
When the macbook is on, i close the screen and when i open 3 hours later the screen turn on but the macbook dont wake up
da
just clean up the machine. or even fresh install
da
Aggiungi la tua risposta
Jonathan Joel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 30
