Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
What does appleacpiplatformexpert start:failed mean
I get the error appleacpiplatformexpert start: failed when I start up in verbose mode. Could that be a power problem with the MacBook caused by a third party unbranded charger
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like you may have used a patcher to try to upgrade your system. If you have appleacpiplatform kext in your usb extensions folder, remove it, the installer should l boot normally.
Punteggio 1
1 Commento:
I took out the hard drive and I got the usual kernel panic that I get, unable to find driver for this platform which suggests bad ram but the ram is brand new
da
Aggiungi la tua risposta
Cheap gamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 186
