Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
Cutting through stripped screw
Hi everyone,
I have a badly stripped screw head and I’m thinking of using a dremel-type tool/rotary saw bit to cut through to get it out.
See attached picture, the bottom image shows where the screw is, and top image shows tiny pillar the screw itself goes into.
I’m thinking of cutting the pillar part — what advice do you all have? What sort of saw bit should I use if this is the best way to solve the problem?
PS Have tried the usual tricks, e.g., a rubber band to fill the screw head, rubber cement to join a screwdriver to the screw, etc.
I’m waiting for a precision screw extractor kit, but in mean time I’m curious for any feedback,
Thanks!
Questa è una buona domanda?
Punteggio 0
2 Commenti
What is your goal here? What are you trying to fix?
da
I'm trying to replace the right speaker/subwoofer assembly. To access that part, I need to remove the optical drive, and the stripped screw is holding that in place.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sometimes there is a better option! I wouldn’t bother with the screw at all, instead I would carefully cut the plastic so the screw can slide out from the side using a sharp knife.
Cutting screws out creates metal dust and chunks which can create electrical issues with shorting unlike plastic which is not conducive.
Punteggio 2
3 Commenti:
That seems like it's workable for sure! Appreciate the guidance, let me try it and I'll report back. Many thanks!
da
Ok! Good news, the cutting worked. This was definitely not a repair for the faint of heart, I encountered a couple more difficult screws on the speaker housing and had to cut through the plastic on those too. Thanks again for your help, @danj !
da
@bzindc - If you're all set don't forget the accept the answer - Thanks!
da
Aggiungi la tua risposta
bzindc sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 60
