Salta al contenuto principale
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Domande Visualizza tutte
ipad stuck in loop of doom
My ipad 2 is stuck in the reboot loop. It does nothing on its own and when plugged to a charging point, the red low battery sign comes and then the apple logo and it repeats infinitely.
I have tried to charge it for a whole day , but still no change.
When I tried to restore and update it , (by first holding the home button and the power button for few seconds and when apple logo comes, holding only the home button),
my Mac says it is trying to restore my ipad, but next moment i get an error saying
“Ipad can not be restored. an unknown error (2015) occured.”
Can some one please help me ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
According to iPhone 5s restoring gives error 2015; screen is broken, 2015 is an error regarding the internal power of your battery which should be replaced.
Couple of questions:
Are you using the original cable & charger (at least 2A)?
How long has your battery been? Are there any signs of battery wear?
Punteggio 0
2 Commenti:
I am using original cable and charger..
the iPad i bought around 7 years back. So quite old. It was left unused for last 1-2 years.
How to check if there is any signs of battery wear?
da
7 years, and 1/2 years of no usage. I'd say the chances of a battery problem is ridiculously high. Try to remember back 2 years ago, any of these symptoms? https://www.androidcentral.com/how-tell-... . If you forgot, best is to take to a technician, ask them to replace your battery. Best, you get it all working. Worst, you lose nothing (since they can't charge you if they don't repair it anyways).
da
Aggiungi la tua risposta
Sam Rout sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 457
