Salta al contenuto principale
Why is my freezer cold, refrigerator not so much? Weak airflow...
Whirlpool GI7FVCXWY01 Freezer is cold, Refrigerator not cold enough.   Air flow is strong in freezer, but weak in refer compartment.   I just emptied and defrosted the fridge thinking that the coils may have been frosted over blocking air flow to fridge box.   Still low air flow into refer.   Any ideas on this one?   Thanks so much!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are about 9 things this could but the first to check is:
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
https://www.repairclinic.com/PartDetail/...
Punteggio 1
2 Commenti:
Thank you Mayer! Now I just have to locate that part in my fridge... any ideas?
da
Look on the wall between the frog and freezer in the lowest compartment (usually the meat drawer)
da
Aggiungi la tua risposta
tdobb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 826
