Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Punctured Battery While Removing
While trying to remove the battery I punctured one of the cells but it still isn’t out yet. There was a tiny puff of smoke at first for a second but nothing now. I am still trying to get all the cells out. Should I be worried about it going up in flames at any moment?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Now that it has been a day, I would put a large piece of electrical tape over the hole. Then very carefully attempt to remove it and I would do it outside and stop at the moment anything suspicious starts. Wear rubber gloves and eye protection.
Punteggio 3
1 Commento:
Thanks, I put the Mac in the fridge and then removed the rest of adhesive with dental floss. Thanks for your help.
da
Aggiungi la tua risposta
RocketBunnyBoy03 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 376
