Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
How to fix home button
hopme button needs a little bit repair bacause it needs more power to push to activate
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Follow that link to take front screens off, turn screens over so you're looking at the back of the home button. You should see 2 very small gold prongs, these get bent flat from use (why you need to press hard now) use a flathead screwdriver to GENTLY lift them up to 45•. Replacing the button won't change a thing... You may need to change the flex under it ($1-3) easy fix
Punteggio 4
The home button is part of the front panel assembly.
You can get the front panel assembly apart from the rest of the iPhone by following this tutorial:
iPhone 3G Front Panel Assembly Replacement
After you have done that try playing with the connectors around the home button, and purchase a iPhone 3G home button from another site if you believe it needs replacing.
Best of luck!
Punteggio 0
Aggiungi la tua risposta
zaeem sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 7
Tutti i Tempi: 773
