Salta al contenuto principale
The Ryobi P235 is a cordless 18 Volt 1/4 Inch impact driver. Ryobi Washer 690266001 x 2 Ryobi Ring 690258001 x 2 Identified by model number: P235
How do I fix the quick connect coupler?
I was using my impact driver and try to change a bit the next thing I know I tried to pull the bed out and the collar a spring washer and retainer clip fell out. Now I’m trying to figure out how I can put it back together, if not I have to send to a Ryobi repair station and wait 2 to 4 weeks for the fix. Anybody have any ideas
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@chascos sounds like it could have come from the Front Gear Case Assembly. check this guide Ryobi P235 Motor Replacement image 7 and see if you can determine if that looks like it should
Punteggio 2
Aggiungi la tua risposta
Charles Cosner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,567
