Salta al contenuto principale
Modello A1311 / FIne 2009 / processore Core 2 Duo 3.06 o 3.33 GHz
20 Domande Visualizza tutte
My iMac won't boot at all
Hi.
I have posted in Apple discussion, found no solutions with software. I think something must be wrong with hardware — was working fine yesterday, then must’ve updated (maybe overheated some part?) and now it will only show a white screen when I click the power button. No chime, no logo, no keyboard input either (using a wired keyboard). So can’t access safe mode, recovery, alt disk, NVRAM reset, anything. Resetting SMC doesn’t work either. I would maybe be willing to replace a cheap part but hope not to buy a new one. Any ideas? Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
PROBLEM SOLVED:
Issue — hard drive!
(Actually, relatively new SSD, but whatever!)
Punteggio 0
Have you tried to hold command+alt+R ?
Punteggio 0
5 Commenti:
I just did and…..nothing :(
da
Try holding shift +control +option (while connected to power source) for 3 seconds the power on ...
If not try holding command +R and boot to safe mode
da
Seems like a corrupt OS or impartial download that’s causing this
da
Hope it isn't hardware, but it will literally not do anything no matter what keystrokes I press..........and smothering the keyboard doesn't work either ;)
da
However the USB ports are providing power. The DVD drive engages when the computer turns on. But no chime, no sign of life besides the blank white screen.
da
Aggiungi la tua risposta
Harrison Gordon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 144
