Salta al contenuto principale
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
No numerical output on minijack
Hello,
No numerical output on minijack connector. Analog is working well. It’s surely an hardware problem. I tried several configurations in sound preferences, midi preferences. Cable is ok working on iMac.Is it possible to clean the connector ?
Regards,
Bertrand.
Questa è una buona domanda?
Punteggio 0
1 Commento:
To be clear you are looking trying to connect via a digital out (optical signal).
da
Aggiungi un commento
2 Risposte
The digital optical signal does require a special cable like this one: Mini Toslink to Toslink Digital Optical Audio Cable 3 Ft Connector Adapter
While faint you should see a red light emitting from the cable aiming it at a white pice of paper in a dimly lit room.
Punteggio 0
Yes, the digital output can stop working because it’s dirty, and you can fix it by cleaning it.
I had this problem on an older, used Mac Mini that had been in a dusty environment. Sound was fine coming from the computer’s speaker and the analog headphone output jack, but when?a mini toslink optical S/PDIF cable was inserted into the same jack the output was silent.
The Mini was sending a red glow out to the opposite end of the cable but no matter what I connected it to or how I configured the software settings, there was no audio. That cable did work when attached to other Macs.
Because of your question here, I shot compressed air from a can into the audio output jack on the Mini, then used a small plastic tool coated in rubbing alcohol to scrape at the back wall of the jack, as well as a Q-Tip with the cotton removed. Then another shot of compressed air. The digital (and analog) outputs worked perfectly afterward.
Punteggio 0
Aggiungi la tua risposta
Bertrand Clech sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 115
