Salta al contenuto principale
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
50 Domande Visualizza tutte
Radiator fan not turning on?
Hey guys I think I have a more complex problem or I have over analyzed my situation with my 1992 Honda Civic 4 Cylinders 1.5L MFI SOHC
Car Overheats after about 5 to 10 minutes of driving. Radiator fan never engages to turn on, I also noticed it takes the coolant but the radiator fan still does not turn on. Checked the fan switch by bridging the current and fan turns on.
I replaced following:
cooling fan relay
temp sensor
fan switch
thermstat
I checked the other fuses underneath the hood and they were all good. Not really sure where to go from here. What are your thoughts
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Alejandro Garcia hat is the exact year, engine size and model for your Civic? That way we can chase the wiring and hopefully get you a good answer.
da
1992 Honda Civic 4 Cylinders 1.5L MFI SOHC @oldturkey03
da
Aggiungi un commento
1 Risposta
check the pigtail on the thermo Switch next to the to the Thermostat housing for loose wires
Punteggio 0
Aggiungi la tua risposta
Alejandro Garcia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 539
