DC-IN socket on motherboard burnt as well as cable (photo)
It still charges for couple minutes and then stops.
It happened while was I gaming and charging the laptop at same time, all of sudden it would stop charging and later I tried again, it worked for couple minutes and stopt. Then I opened laptop and found out this.
Any help would be appreciated. The laptop was bought in USA but I am in EU in case it has anything to do with parts.
Questa è una buona domanda?
5 Commenti
Hello,
I have the same problem. I would like to know if you found the keyword or the name for the connector in the motherboard?
Thanks
da Frédéric Settama
Hi mine was burnt really bad too but I just bought a new cable cheap online and put it in and worked fine no preformace difference too. Its the only way to fix as I couldn't find a new dc jack which on the board . Also even if some pins break it will still work
da madasar_ali
Thanks for your reply. I will try :)
In the connector there are some parts of the old connector I don't know if I can clean them correctly.
da Frédéric Settama
Hey guys could you share the link to the cable replacement. I’ve only been able to find one for the older models that have a different charging port.
da blposey16
https://www.ebay.ca/itm/Razer-Blade-RZ09...
If you need the housing I can link you the housing
da Elusive
