Salta al contenuto principale
garmin navigator wont turn on
my garmin smart drive 60 wont turn on …it was plugged in overnight & a cold front came thru…now wont turn on…wanted to take back off to reset battery cable but dont have torx driver that tiny…
Questa è una buona domanda?
Punteggio 1
1 Commento:
I have a Smart Drive 51 with the same problem. I removed the battery and tested the battery. It was reading 3.982v. I’m not sure if I should buy a new battery or not.
da
Aggiungi un commento
1 Risposta
@harveysgarmin the very first thing you will definitely need to try is a new battery. Once installed, re-evaluate. Some of the battery kits like this one actually comes with their own tools. Of course you can always purchase a kit like this one Manta Driver Kit - 112 Bit Driver Kit so you will always have the right tool for those cool jobs :-)
Immagine Our most comprehensive bit kit for the ultimate repair enthusiast. 112 bits designed to fix every household tech device.
Prodotto
$69.95
Punteggio 0
Aggiungi la tua risposta
HARVEY MELCHER sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 327
