Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191 Domande Visualizza tutte
Read the old SSD out of unit and use as external drive?
Hi Guys,
I'm looking for a way to take out the SSD out of the unit and be able to read it externally on a Mac.
Reason
I am an engineer and have clients with dead units and I am guessing the the data on the SSD would be fine (no way of knowing at this stage) and would like to be able to take out the SSD and see if I can get to the data for my clients, is there a reader of some sort for this?
Thanks in advance for your help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Soluzione Prescelta
I bought the external case with the new ssd, and it came with a little adapter for SATA, I was talking about
so now I plan to put the old macbook air's ssd in my iMac as a second drive with this adapter
Punteggio 1
2 Commenti:
I am looking for a while an external solution for this special SSD , so that I can use it as a startup drive on a desktop computer.
the only available one today is the one from OWC: Air SSD enclosure
thats a great enclosure cause as you can see on the pictures, it includes a special adapter for SATA. So I though that I can use that adapter to use the SSD in inside of any computer.
I contacted them, they don't feel the adapter alone. Thats too bad cause the whole enclosure shipped to europe cost 100 dollars in total + customs. So it becomes an absurd price for a just simple enclosure, but it is the only one in the market.
Ah if you buy a new SSD from them they do a discount but still too much shipping costs. So we europeans got no choice yet :(
da
so law enforcement claim they can recover any data on a hard drive deleted or not so there must be a way unless they are talking **** as usual
da
Risposta Più Utile
Found one... that should do the trick for any tech... http://bit.ly/JBSpli
Punteggio 1
While an SSD-to-USB case does not yet appear to be available, you can create an USB boot drive (or a thumb boot drive) and install the SSD from a damaged MBA in your known good MBA. You should be able to recover any readable files from the SSD. But, you're an engineer and have already thought of this.
Punteggio 0
OWC sells a USB enclosure for $35 US, but according to their website it is only available when you purchase an upgrade SSD from them. More information can be found here.
Punteggio 0
Other world computing has two external cases.
http://eshop.macsales.com/item/OWC/SSDAP...
to be release soon
http://eshop.macsales.com/shop/drive/enc...
Punteggio 0
Aggiungi la tua risposta
iFreak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 21,228
