Salta al contenuto principale
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
53 Domande Visualizza tutte
Dishwasher not starting. All lights working.
I have a Whirlpool Quiet Partner II. Yesterday, I noticed that while other buttons were working (i.e. the cancel button), the start button would not work when pressed.
I have reset the control panel by pressing sani-rinse, heated dry, sani-rise.
  • When I do so, the start button lights up with all the other buttons.
  • I then close the door, and Start/Resume turns on. The dishwasher makes a loud sound on the normal cycle, washing status, then it hums, makes a sound like it is draining
  • It then goes to the rinse only cycle and washing status, and continues to hum/drain
  • Finally, all the lights turn back on
When this is over, I still cannot get the start button to work.
Any thoughts are appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
When you push the start button do any lights flash?
If the clean light flashes seven times you have a heater error and the board is locked out. You will have to diagnose whether the problem is the board, heater, tco ot thermister.
If a light above a button flashes quickly it means that button is stuck and the console with UI needs to be replaced.
If there is no response whatsoever from the unit when the start button is pressed chances are the console with the UI needs to be replaced.
You can use the model number to find the part on any number of sites. If you replace the console I would strongly recommend replacing the board thermal fuse as well, it tends to go out a few days after touching the wires in the control area.
Punteggio 0
Aggiungi la tua risposta
Becky Armstrong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 911
