Keep getting a starting system disabled on 2006 Lacross
I keep getting a starting disabled message while driving my 2006 Buick Lacross. And it shuts off. Disabling everything while I'm driving… power steering and engine. I let it sit for a couple of minutes after I manage to pull over and then it starts up again. I also get a couple of other messages like service IBS system soon and service traction system also when this happens. Any clues?
Questa è una buona domanda?
2 Commenti
I had the same problem but it didn't shoot out a code.Dealership had it for a whole day before it ran a code.Turned out it was the PCM.
da jim hurn
My wife's 2005 CX Lacrosse 3.8L had this exact same problem. The cause was a 7 year old battery and corrosion buildup around the positive terminal.
After replacing the battery and cleaning the connections I tried several component changes based on CEL codes with no success. I just finished spending about 1.5 hrs. doing an ignition key relearn procedure, it takes persistence, after purchasing and installing a refurbished and reprogramed ECM from Flashmaster's ECM in Cincinnati.
Car is back to normal, runs like new again.
The problem, "starting disabled, and reduced engine power" are gone as are the CEL codes P0601, P0606 and U0107.
da Charles Gallagher
