Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
Mini Display Port Male to Male Cable vs Thunderbolt to Thunderbolt
Hello all
Before I spend my money on expensive Thunderbolt cables. I want to use a machine to check another machines display, mirror the contents on a bigger screen.
I ask this question; has anyone successfully connected their MacBook Pro to iMac using a mini display port male to male cable ? (plugged into both thunderbolt ports on both machines) CMD + F2 ?
I know a Thunderbolt to Thunderbolt cable will do it, but they are stupidly overpriced!
Will the mini display port cable male to male do the job ?
Any downsides to using the mini display male to male cable ?
I know I could check the display using a mini display port cable to HDMI adapter and just connect direct to TV also.
Thanks for reading.
Update (02/09/2020)
Thanks Dan.
I bought an Apple Thunderbolt cable to connect Mac to Mac.
However I wouldn’t mind buying one of these Thunderbolt Mini Display port to HDMI cables. Just as a back up to connect a machine to HDMI port on a TV.
I’ve read a few reviews whereby audio is not present on some machines or visual picture isn’t very good.
Does anyone know if Apple do their own Thunderbolt Mini Display to HDMI cable or what’s the best after market cable that supports both audio and visual?
There’s too many cheap ones like this one for sale.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Apple did offer both standard DisplayPort and miniDP as well as TB1/2 to HDMI adapters and cables years ago.
As time has marched on, finding a real Apple adapter or cable today will require a bit of searching.
As far as dual channel support (vid & audio) the older DisplayPort cables tended to be the ones that might not offer the audio feed. In addition, the display might not offer speakers so it would be pointless having the connection present within it.
da
Aggiungi un commento
1 Risposta
Sadly, the DisplayPort cable is strictly that for a display, it’s not a fully wired Thunderbolt cable.
Which is why you do need the Thunderbolt cable as its a superset of connections and the wires are more fully shielded.
Update (02/10/2020)
I remembered there is a great Apple T/N that goes over Target Display mode Use your iMac as a display with target display mode
Sadly, Apple has pulled the feature from Mojave and newer macOS’s. And its usefulness is much less in newer systems as well.
Frankly, I just use a display which supports DP & HDMI connections as my test display.
Punteggio 0
Aggiungi la tua risposta
Bz8B1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 591
