Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
iPod displays folder icon error
I have a 4th generation 20gb iPod (mono) that is displaying the folder error icon. So I have replaced the logic board. I have also replaced the original drive with a iFlash-ATA1 adapter and a Samsung 128gb SD.
After all that, the iPod still displays the folder error and my computer does not see the iPod when it is connected.
Any ideas about what I should/can do next?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@sneatonscott your computer most likely will not recognize it since you have no firmware/OS on the iPod drive. I suggest you try it with a regular HDD first and then see what it tells you.
Punteggio 1
2 Commenti:
I did try that first. I had the same problem. But I’ll try it again.
But if nothing changes, do you have any other suggestions?
Thanks.
da
Have you tried to place it into diagnostic mode with a HDD installed?
da
Aggiungi la tua risposta
Scott Eaton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 297
