Salta al contenuto principale
Screen turn red on MBP 17
My MBP has a red artifact on the screen when turn on. Sometime it goes back to normal.
Also I connected to an external monitor and it look normal
Do I replace the Display cable or the LCD?
http://i78.photobucket.com/albums/j87/lu...
Update
Brought a new LCD: the problem still there
Going to try the changing the inverter and data cable
Questa è una buona domanda?
Punteggio 1
3 Commenti
Please give us the last three figures of your serial number. Thanks
da
Apple MacBook Pro "Core 2 Duo" 2.4 17" (SR) Specs
Identifiers: Mid/Late 2007, 2.4GHz* - MA897LL/A - MacBookPro3,1 - A1229 - 2137
da
thanks guys
I did take it to the Apple store; they said that the Video card is fine
they said it was the LCD
I am going to open ut up on the weekend to see if it the cable
da
Aggiungi un commento
9 Risposte
Risposta Più Utile
This is caused by a bad LCD panel, usually when exposed to excessive heat, or sunlight. I had my old LCD TV do the same thing (I left it facing a window, and somehow the direct sunlight it was damaging it over time, and causing it to fade to red) When it goes back to normal, is it spontaneous, or does it fade back to normal colors? Also, do you keep the computer in a hot, or bright (From sunlight) environment? That would be the likely cause of the problem. Here is a replacement panel, and Here is a guide to replace the panel.
Punteggio 2
x94
Punteggio 0
Yes
it is
Punteggio 0
First, I would take the computer apart, the LVDS cable may be loose or may need to be replaced
If that isn't it, I would go ahead and replace the screen, it may be bad
If that doesn't help(mayer, I have done my homework), it could have a NVIDIA issue and apple will fix it free
Punteggio 0
Had a spare LVDS cable, same problem>
I am waiting for an invertor
Punteggio 0
its not the inverter, it the inverter/antenna cables
Punteggio 0
hi lunchbx2, i've been encountering this problem for the past 6 months and can't find a fix. They told me to replace the lcd but i find it kinda expensive. Were you able to trace the problem?
Punteggio 0
Hi
Dont trust Apple Genius. If I paid them to replace the LCD then I would had the same problem
I have replace the screen and inverter; had a spare data cable and it didn't work.
I'm trying to get hold of an inverter/antenna cable to see if was that.
Also when I press some part of the top left or right casing the screen goes back to normal
Gonna check the top casing to see if there a short too ;-)
Punteggio 0
I taken the laptop to Apple Genius and told them it wasnt the logic board
They came to the conclusion (which I knew) it was the logic board and wanted $315 to fix it
Punteggio 0
Aggiungi la tua risposta
lunchbx2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,764
